Hi, I have the following chunk of code: unsigned char code A[4]={3,'L','P','L'} unsigbed char code B[3]={2,'P','P'} If a customer by means of a keyboard, writes the letter A in a variable a pointer must point for the Array A[4], if instead writes the B letter, must point for the Array B. How can I realize this function with a Pointer? Best regard Antonello
unsigned char code A[4]={3,'L','P','L'}; unsigned char code B[3]={2,'P','P'}; char customerChar; unsigned char code *p; if (customerChar == 'A') p = A; else if (customerChar == 'B') p = B;
Quibble: the above code falls through with an undefined value for p if customerChar is neither A nor B. It should have another else for error handling, or perhaps a default value:
p = A; if (customerChar == 'B') { p = B; }
switch (customerChar) { case 'A' : p = A; break; case 'B' : p = B; break; default: // unexptected value for customer char // error handling code goes here p = NULL; break; }
