Why uVision2 does not simulate 8952. This compiler does not understand 8952 register(example TR2, T2MOD, T2CON...) Nguyen The Son
I'm quite positive it does simulate that chip --- but you have to tell the IDE what chip it's supposed to be simulating, and the compiler what chip it's going to generate code for. Did you?
uVision supports T2 on both the Atmel AT89C52 and the ISSI IS89C52. I found no other 89C52 devices. Atmel AT89C52 - http://www.keil.com/dd/vtr/2980/1898.htm ISSI IS89C52 - http://www.keil.com/dd/vtr/3053/1898.htm Jon
