I'm currently doing a project on an MX2 based system and I'm having trouble locating my code to the correct location. My memory map is as follows: 512k off-chip RAM at X:000000 64k on-chip ROM at C:800000 512k off-chip Flash at C:900000 The project has two parts: 1. Boot code - in on-chip ROM 2. Application code - in off-chip Flash The boot code needs to detect a valid application in the Flash and run it OR display an error via the com port (I have done this already). I guess the boot code will jump to a code address in Flash (probably C:900000) in order to run. I've set my off-chip code memory to start at 0x100000 and have a size of 0x80000 but the map of my application code still shows code in the C:800000 - C:8FFFFF range, which I think is wrong. Has anyone else out there done something similar and can point me in the right direction? I'm new to the MX2, so please be gentle with me :)
Further to my query yesterday I found an example on the Keil website that almost does what I require.
http://www.keil.com/support/docs/337.htm
I think the answer: http://www.keil.com/support/docs/2682.htm covers what you are looking for.
