I am using keil mcbstm32f400 and I want a timer to generate interrupt every 2ms .I have written the code but i want some guidance whether i am approaching the problem in a right way.My doubts have been put in the comments in the code, some of them are basic doubts but i still asked them as i wanted to clear my concepts.I also wanted to know how to disable interrupts at beginning of isr and enabling interrupts before going out of isr. Timer calculation= 2ms=16mhz/{(12499+1)*(63999+1)}
#include "stm32f4xx_hal.h" // Keil::Device:STM32Cube HAL:Common #include "cmsis_os.h" // ARM::CMSIS:RTOS:Keil RTX #include "Board_LED.h" // ::Board Support:LED #include "Board_Buttons.h" // ::Board Support:Buttons #include "Board_ADC.h" // ::Board Support:A/D Converter #include "RTE_Components.h" // Component selection //#include <EventRecorder.h> #include "GLCD_Config.h" #include "Board_GLCD.h" #include "Board_LED.h" #include "Board_ADC.h" #include <stm32f4xx_hal_tim.h> //static TIM_HandleTypeDef htim2; static TIM_HandleTypeDef s_TimerInstance = { .Instance = TIM2 }; //extern "C" void TIM2_IRQHandler() extern void TIM2_IRQHandler() { HAL_TIM_IRQHandler(&s_TimerInstance); } void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim) // HERE *htim is correct or &HTIM2 WILL COME OR &S_TIMERINSTANCE { //IN THIS ISR HOW TO DISABLE INTERRUPT AT BEGINNING AND HOW TO ENABLE INTERRUPT BEFORE GOING OUT OF ISR ADC_Initialize(); HAL_GPIO_TogglePin(GPIOD, GPIO_PIN_12); } void InitializeTimer()//FOR 2ms TIMER WITH INTERRUPT PRESCALER AND PERIOD VALUES ARE CORRECT OR NOT ASSUMING 16MHZ CLOCK ,ALSO HOW TO CONFIRM THE CLOCK SPEED OF TIMER { __TIM2_CLK_ENABLE(); s_TimerInstance.Init.Prescaler = 63999; s_TimerInstance.Init.CounterMode = TIM_COUNTERMODE_UP; s_TimerInstance.Init.Period = 12499; s_TimerInstance.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; s_TimerInstance.Init.RepetitionCounter = 0; HAL_TIM_Base_Init(&s_TimerInstance); //HAL_TIM_Base_Start(&s_TimerInstance); HAL_TIM_Base_Start_IT(&s_TimerInstance); } void main(){ osKernelInitialize(); /* initialize CMSIS-RTOS */ HAL_Init(); /* Initialize the HAL Library */ SystemClock_Config(); /* Configure the System Clock */ LED_Initialize(); /* Initialize LED */ //Buttons_Initialize(); /* Initialize Buttons */ ADC_Initialize(); /* Initialize ADC */ GLCD_Initialize(); /* Graphical Display Init */ GLCD_SetBackgroundColor (GLCD_COLOR_WHITE); GLCD_ClearScreen (); GLCD_SetForegroundColor (GLCD_COLOR_WHITE); GLCD_SetBackgroundColor (GLCD_COLOR_BLUE); GLCD_SetFont (&GLCD_Font_16x24); GLCD_DrawString (0, 9*24, " constant temp "); InitializeTimer(); HAL_NVIC_SetPriority(TIM2_IRQn, 0, 0); HAL_NVIC_EnableIRQ(TIM2_IRQn); //remaining code }
Some background reading in your other thread: http://www.keil.com/forum/64032/#/msg211117
