Does the SMTP client support sending secured emails?
Thanks. The link graphics doesn't match my Software Packs screen from the latest 5.26 compiler, so it is not useful. There are no options that look like the link you sent. Maybe I'm missing something.
Sutton
Check if you have selected the Network “MDK-Pro” Variant. Then you should also see the “SMTP Client” SMTPS variant.
I don't see that selection at all. Where is that selection located? Under Pack Installer? Please be very specific with exactly where to go. Thanks.
Take another look at the documentation at the link provided earlier: www.keil.com/.../use_secure_components.html
It shows the “Manage Run-Time Environment” window (http://www.keil.com/support/man/docs/uv4/uv4_ca_rtemanager.htm).
Click on Network component and select “MDK-Pro” variant. Expand Network and Service and click on SMTP Client and select SMTPS variant.
Note: you need MDK-Middleware pack installed (comes pre-installing MDK)
MDK-Middleware is installed and up to date in my 5.26 compiler version according to the Pack Installer. But the Run-Time Environment is grayed out in the drop down menu. What next?
If you have middleware, you must have a licence - and, thus, be entitled to support.
So may be easier to contact Keil support direct; then you will be able to share screenshots, etc - and not be limited by the forum.
