Thank you in advance. here is the problems: 1. With the same priority, which task (task 1 or task 2) should run first? 2. If interrupt 0 should be reset after task 1 has been triggered? 3. Why task 2 keeps in ready and task 1 keeps in running (Round-Robin problem?)? 4. In RTX 51 full, how can I disable and enable all interrupts at one time? May I do it like what I have done in function_1? 5. I have to mark function_1 as reentrant function? 6. In task1, what is the difference between clear signal (task1) and unclear signal (task1)? void init() _task_ INIT { os_create_task(TASK1); os_create_task(TASK2); os_enable_isr(0); } void int0() interrupt 0 { isr_send_signal(TASK1); } void task1() _task_ TASK1 _pirority_ 1 { while(1) { os_wait(K_SIG+K_TMO,10,0); os_clear_signal(TASK1); /* I have to do this?*/ /* task code*/ function_1(); os_send_signal(TASK2); } } void task2() _task_ TASK2 _pirority_ 1 { while(1) { os_wait(K_SIG+K_TMO, 10, 0); /* task code */ function_1(); } } function_1() large reentrant /* I have to mark it?*/ { EA=0; /* code */ EA=1; }
"4. In RTX 51 full, how can I disable and enable all interrupts at one time? May I do it like what I have done in function_1?" Have you looked at
#pragma DISABLE
