Hi,I have got a 12864 graphic lcd but haven't got the its datasheet. Can anyone help me any infomation on this? I want to use the 89C51 to control it. Thank Lisette de Valmy.
"Hi,I have got a 12864 graphic lcd but haven't got the its datasheet." Well, go and GET the datasheet then! Stefan
Dear Stephan, Where can I download the datasheet? Lisette.
Google. Stefan
"Where can I download the datasheet?" Where did you get the LCD?
1. I have found by google, but only found the datasheet with mechanical specifications. 2. I remove it from an old equipment.
"I have found by google, but only found the datasheet with mechanical specifications." It took me 30 seconds to find this: http://home.nikocity.de/woe/lcd/pg12864.pdf Stefan
Hi Stefan Duncanson, By your help, I have downloaded the 12862 datasheet. I am very happy. Thank you! Lisette de Valmy.
i want datasheet for 12864lcd
"i want datasheet for 12864lcd" If you actually read the thread, it tells you where to get it. You only need to click the link - it's not difficult!
