Message 15 as general receive message
Hello!
I want to use the message object 15 as a general receive object.
Message 1 .. 14 are used for transmit objects.
I used 0x000 as mask for the message 15 and didn't fill the arbitration register.
(I use a Siemens/Infineon C167CR processor.)
When a message is received an interrupt is generated, but I fail getting the
message ID out of the arbitration field.
I tried the following code:
dummy_int1=UAR_MO15;
RCV_ID=(unsigned long) (((dummy_int1<<8)+(dummy_int1>>8))>>5);
But I always get "0" as result ...
Any ideas where the problem is? Is it necessary to fill the arbitration register
even if i want to receive multiple IDs?
Unfortunately the CAN chapter at the User's Manual for the C167CR didnt't
help me!
Thanks in advance!
SVEN
