Reset button from IDE
Is there a button to reset the microcontroller? After program it sometimes is necessary perform a reset more than one time to debug or any reason and is more comfortable to do it from keil instead of power cycling.
  • Yes, but this does almost exactly what the OP is asking for and the reasons given for not wanting to do it dont exist.
    1) You do not need to start in Debug mode.  issue resolved.
    2) when the issue happens - connect to board.  DO NOT start debugging or load code. Just connect to board.   This is not in any way slow.
    3) Now you can use the RST button in the IDE just as you would like.
