I have built a simplest possible system viewer for uVision. The problem is that it does not refresh variable value, it sticks on the first reading. I will apreciate any helps, thank you in advance. Georg
<component_viewer schemaVersion="0.1" xmlns:xs="">www.w3.org/.../XMLSchema-instance" xs:noNamespaceSchemaLocation="Component_Viewer.xsd"> <component name="MyFirstComponent" version="0.0.1"/> <!-- name and version of the component --> <typedefs> <typedef name="MyGeneralType" info="This is MyType with 2 members" size="12"> <member name="hi" type="uint32_t" offset="0" info="member 'mysymbol.hi'"/> <member name="low" type="uint32_t" offset="4" info="member 'mysymbol.low'"/> </typedef> </typedefs> <objects> <object name="MyFirstObject"> <read name="My2ndSymbol" type="uint32_t" symbol="LoRaWatchTimer" /> <out name="My First Viewer"> <item property="LoRaWatchTimer" value="%d[My2ndSymbol]" info="Show HEX value of 'mysymbol.low'" /> </out> </object> </objects> </component_viewer>
