I downloaded the latest SDK (2.5.0) for LPCXpresso54018M board from NXP for KEIL IDE.
I connect to the target via P1 (external debug probe) with ULINK2-ME Sieger probe. When I attempt to start a debug session for any examples from the SDK, KEIL IDE is always giving me the following error:
"ERROR FLASH DOWNLOAD FAIL"
The log from KEIL IDE shows:
Load "D: \\54S018M_SDK_2.5.0\\keyboard2mouse_bm\\debug\\keyboard2mouse_bm.out" No Algorithm found for: 00000000H - 0000A7BFH Erase skipped! Error: Flash Download failed - "Cortex-M4" Flash Load finished at 14:39:54
Please note I am attempting to debug from RAM (not flash) , the linker setting are set correctly (default setting from the SDK example) .
Please note the debug setting (default from SDK example) are also correct. They are as follow (jlink_sramx_debug.ini)
FUNC void setup(void) { SP = _RDWORD(0x00000000); /* Load the SP value from RAM vector table. */ PC = _RDWORD(0x00000004); /* Load the PC value from RAM vector table. */ _WDWORD(0xE000ED08, 0x00000000); /* Relocat the vector vable to RAM table. */ }
FUNC void OnResetExec(void){ exec("LOAD %L INCREMENTAL");
setup(); }
/* Load the image file into SRAMX*/ LOAD %L INCREMENTAL setup();
//g, main /* Run to main. */
Please note the probe work, the debug attempts on LPCXpresso5460x8 board with the same probe work w/o problem.Although it download into FLASH not RAM
