When I create a new project with uVision 5, the target options tab shows only "Xtal" and "Operating system". The fields that appeared in the past, "Code Generation", "Read/Only Memory Areas", and "Read/Write Memory Areas" are missing, even though the device is the same as before. The new project cannot assemble code properly. It interprets assembler directives as instructions.
Never mind, I figured it out.
