In the documentation and web information doesn't indicate data port range in ftp server.
My version of net_config.c is:
/*---------------------------------------------------------------------------- * RL-ARM - TCPnet *---------------------------------------------------------------------------- * Name: NET_CONFIG.C * Purpose: Configuration of RL TCPnet by user. * Rev.: V4.22 *---------------------------------------------------------------------------- * This code is part of the RealView Run-Time Library. * Copyright (c) 2004-2011 KEIL - An ARM Company. All rights reserved. *---------------------------------------------------------------------------*/
Thanks for all
www.danlhenry.com/.../keil_code.png
The url didn’t work
Oh well, just read the instructions, then: they're right above the box where you type your post - between where it says "Summary:" and where it says "Message:"
must've worn it out after nearly 12 years use ...
http://www.keil.com/forum/10699/
