Keil 5.24 + AT45DB642D. Why so hard?
Hi everyone!
. I try to use EFS(Embedde File System) with Keil 5.24 for AT45DB642D.
I read manual www.keil.com/.../fs_create_app.html
And config my project as described. For SPI flash.
Initial current drive = F0.
But i got a lot error after compilation. Like this:
C:\Keil_v5\ARM\PACK\Keil\STM32H7xx_DFP\2.2.0\Drivers\BSP\STM32H743I_EVAL\stm32h743i_eval_nor.c(416): error: #20: identifier "NOR_HandleTypeDef" is undefined
C:\Keil_v5\ARM\PACK\Keil\STM32H7xx_DFP\2.2.0\Drivers\BSP\STM32H743I_EVAL\stm32h743i_eval_nor.h(124): error: #20: identifier "NOR_IDTypeDef" is undefined
Could anyone give me advice how to use EFS for spi flash?
P.S. I used Keil 4.54 before. And it was not so hard to use AT45DB642D.
There were few files : ARM-RL library,FILE_CONFIG.C, FS_SPI_FLASHPRG.C.
Best regards, Vladimir
  • error: #20: identifier "NOR_HandleTypeDef" is undefined
    and
    it sounds like you have omitted to #include a required header file or files ...
  • I decided to build new project. And after that i got next error:
    Error: L6218E: Undefined symbol Driver_SPI0 (referred from at45db641e.o).
    I have next RTE Configuration:
    CMSIS -> Core
    CMSIS -> RTOS2(API)->Keil RTX5
    CMSIS Driver -> Flash -> AT45DB642D
    CMSIS Driver -> SPI(API) -> SPI
    Compiler -> Event Recorder
    Compiler -> I/O -> File
    Device -> Startup
    Device -> STM32Cube Framework (API) -> STM32CubeMX ( SPI #1 activated Full Duplex Mode)
    Device -> STM32Cube HAL -> Common
    Device -> STM32Cube HAL -> Cortex
    Device -> STM32Cube HAL -> DMA
    Device -> STM32Cube HAL -> GPIO
    Device -> STM32Cube HAL -> MDMA
    Device -> STM32Cube HAL -> PWR
    Device -> STM32Cube HAL -> RCC
    Device -> STM32Cube HAL -> SPI
    File System -> CORE
    File System -> Drive ->NOR ( 1 pcs)
    All drivers installed. How could i fix my error?
    Best regards, Vladimir.
  • That's a Linker error.
    So you've used a function without providing any definition (aka implementation) of it.
    Most often, this is because you've #included a header, but have not provided the corresponding source or binary library file.
    www.keil.com/.../armclang_err_dom1365073159742.htm
  • Hi everyone!
    I found solution for this problem.
    It's necessarry set DRIVER_SPI_NUM=1 for Spi_drive 1 in Target - > C++ define.
    But after that i have problem with SPI interchange.
    There is no try to send or receive bytes.
    fcheck ("F0:") return: fsAccessDenied.
    functions:
    static int32_t ReadData (uint32_t addr, void *data, uint32_t cnt)
    static ARM_FLASH_STATUS GetStatus (void)
    Not calling.
    How it is possible to see what is inside fcheck() functions.
    P.S. finit("F0:") return fsOK.
  • Does anyone have Project example for Keil 5(EFS) + AT45xxx ?
  • Hi everyone! The problem is solved.
    For build AT45DB161D.c it's better to use AT45DB642D.c
    Because it's correct to use : /* buf[4..7]: don't care */
    But in AT45DB641E.c use inappropriate: /* buf[4...5]: don't care */
    static int32_t ReadData (uint32_t addr, void *data, uint32_t cnt) {
      uint32_t page_addr;
      uint32_t page_offs;
      uint8_t  buf[8];
      int32_t  result;
      if (data == NULL) {
        return ARM_DRIVER_ERROR_PARAMETER;
      page_addr = addr / PAGE_SIZE;
      page_offs = addr % PAGE_SIZE;
      addr = (page_addr << 11) | page_offs;
      /* Prepare Command with address */
      buf[0] = CMD_READ_DATA;
      buf[1] = (uint8_t)(addr >> 16);
      buf[2] = (uint8_t)(addr >>  8);
      buf[3] = (uint8_t)(addr >>  0);
      /* Select Slave */
      result = ptrSPI->Control(ARM_SPI_CONTROL_SS, ARM_SPI_SS_ACTIVE);
      if (result != ARM_DRIVER_OK) { return ARM_DRIVER_ERROR; }
      /* Send Command with Address */
      result = ptrSPI->Send(buf, 8);
      if (result != ARM_DRIVER_OK) { goto transfer_error; }
      while (ptrSPI->GetDataCount() != 8);
