Can anyone explain the codes below, I am completely new to C, and I think there is some mistake in Code 1
Code 1
GLOBAL __main AREA Program, CODE, READONLY __main MOV R0, #625 ; input MOV R1, #0x8000 MOVS R2, #0 sqrt_loop ADDS R2, R2, R1 MUL R3, R2, R2 CMP R3, R0 IT HI SUBHI R2, R2, R1 LSRS R1, R1, #1 BNE sqrt_loop SVC 0x11 END
Code 2
GLOBAL __main AREA Program, CODE, READONLY __main MOV R6,#8 ; MOV R4,#8 MOV R7, #0xFFFF ; MOVT R7, #0xFFFF LDR R8,=TAB1 loop1 LDR R0,[R8], #4 MOV R5, #0; CMP R7,R0 BLS toto1; MOV R7, R0 ; SUB R5, R4, R6 toto1 SUBS R6,R6,#1 BNE loop1 ; SVC 0x01; ALIGN TAB1 DCD 0xE123, 0x981,0xFFFFFFFC,0x73,0x61B1,0xC54,0xD01A,0x720,0x4C15 END
It's not C.
As already noted, it is not 'C' !
It is Assembler.
Assembler is not standardised across processors - so it's important to know what Assembler this is.
You could start with some books on the principles of assembly programming: http://www.keil.com/books
Try cargocoderwankers.com also
