I see you provide the source for many flash loaders, but only the .FLM file for the STM32F7xx_QSPI_Disco loader.
Can I receive the source for STM32F7xx_QSPI_Disco.FLM?
Is it possible to get a quick update on this? I read in another thread that the source should be available for these QSPI FLASH downloaders.
This is a user forum, if you want support from staff read the instructions provided when you entered the forum. http://www.keil.com/forum/
Perhaps you should experiment with the QSPI support on your platform, and then port that to a loader template. ST has BSP examples for the QSPI on the DISCO boards. Custom boards will require additional effort.
Thank you.
Every vendor monitors their forums in a different way and I missed that Keil doesn't monitor their board.
I will work with ARM directly on this.
Did you found the source code? I am looking for it too but cannot found it.
