issue with mdk_pro_eval
I would like evaluate MDK professional with 7 days trial, after activating mdk_pro_eval in license management,I encountered an issue during compilation step.
Build output:
*** Using Compiler 'V5.06 update 5 (build 528)', folder: 'D:\Keil_v5\ARM\ARMCC\Bin'
Rebuild target 'F746ZGAiMdkProject'
assembling startup_stm32f746xx.s...
startup_stm32f746xx.s: Error: A9555E: Failed to check out a license.Trusted Storage open failure
startup_stm32f746xx.s: Feature:       mdk_pro_eval_armcompiler
startup_stm32f746xx.s: License path:  c:\program files\arm\licenses\license.dat;
startup_stm32f746xx.s: FlexNet Licensing error:-158,61003
startup_stm32f746xx.s: Check that your license details are correct in the License Management dialog of MDK. Additional information is available at:
startup_stm32f746xx.s:  - ARMLMD_LICENSE_FILE: unset
startup_stm32f746xx.s:  - LM_LICENSE_FILE: unset
startup_stm32f746xx.s:  - ARM_TOOL_VARIANT: unset
startup_stm32f746xx.s:  - ARM_PRODUCT_PATH: unset
startup_stm32f746xx.s:  - Product location: D:\Keil_v5\ARM\sw\mappings
startup_stm32f746xx.s:  - Toolchain location: D:\Keil_v5\ARM\ARMCC\Bin
startup_stm32f746xx.s:  - Selected tool variant: mdk_pro_eval_flex
startup_stm32f746xx.s:  - Checkout feature: mdk_pro_eval_armcompiler
startup_stm32f746xx.s:  - Feature version: 5.0201701
startup_stm32f746xx.s:  - Flex error code: -158
startup_stm32f746xx.s: Product: MDK Professional 5.24 (Evaluation)
startup_stm32f746xx.s: Component: ARM Compiler 5.06 update 5 (build 528)
startup_stm32f746xx.s: Tool: ArmAsm [4d35e1]
If necessary I can add some information available in my TOOLS.ini file?
For your information I don't have licence.dat file besides "License path" indicated above in bold doesn't exist?
I have also an issue regarding "Product location" mappings doesn't exist under D:\Keil_V5\ARM\sw (in spite of right path).
I don't know what is wrong in my configuration, any help will be appreciated.
Thank you.
  • I assume that you use: MDK Professional 5.24 (Evaluation-Version)
    If yes:
    - Unfortunately, the 7 day MDK Pro evaluation does not work with i.e. the ARM compiler versions ARMCC 5.0.6u5 and ARMCLANG 6.7
    Resolution:
    - update your installation to a later release of MDK: http://www2.keil.com/mdk5
  • Thank you for the reply, in spite of the upgrade of MDK to the latest version 5.27 I can 't compile my project hereinafter the log:
    Rebuild started: Project: F746ZGAiMdkProject
    *** Using Compiler 'V5.06 update 6 (build 750)', folder: 'D:\Keil_v5\ARM\ARMCC\Bin'
    startup_stm32f746xx.s:  http://www.keil.com/support/man/docs/license/license_management.htm
    startup_stm32f746xx.s:  If you need further help, provide this complete error report to your supplier or license.support@arm.com.
    startup_stm32f746xx.s:  - Feature version: 5.0201709
    startup_stm32f746xx.s:  - Flex error code: -1002
    startup_stm32f746xx.s: Product: MDK Professional 5.27 (Evaluation)
    startup_stm32f746xx.s: Component: ARM Compiler 5.06 update 6 (build 750)
    startup_stm32f746xx.s: Tool: ArmAsm [4d35ec]
    compiling hargithub.c...
    Error: C9555E: Failed to check out a license.
    Tool: ArmCC [4d3637]
    "F746ZGAiMdkProject\F746ZGAiMdkProject.axf" - 34 Error(s), 0 Warning(s).
    Target not created.
    Build Time Elapsed:  00:00:06
