Hard fault in SystemInit_ExtMemCtl()
Hi
I hope someone here can help guide me.
I'm using a custom designed board which uses the same SDRAM memory configuration as the ST32429I-EVAL board.
In the Keil file system_stm32f427x.c I have uncommented
#define DATA_IN_ExtSRAM
so that the procedure SystemInit_ExtMemCtl() is called.
The very first line of this procedure is
/* Enable GPIOD, GPIOE, GPIOF and GPIOG interface clock */
RCC->AHB1ENR   = 0x00000078;
This line causes a hard fault after jumping back to system_stm32f427x.s and then trying to jump to __main.
If I comment that line out then the code jumps to __main with no problems.
The strange thing is, if I add a breakpoint to the line right after
// RCC->AHB1ENR   = 0x00000078;
and then change the RCC->AHB1ENR register manually so GPIOD, GPIOE, GPIOF and GPIOG interface clocks are enabled the code runs fine into __main.
Even though the code now runs I haven't got the external RAM to work yet so this may be part of a bigger problem or a configuration problem.
I'm using an old version of uVision V4.71.2.0 so does anyone know if there were bugs in the Keil provided system_stm32f427x.s and system_stm32f427x.c files?
Any help would be appreciated.
  • I just realised I made a typo above, when I said "system_stm32f427x.s" I meant "startup_stm32f427x.s"
  • Hello Simon,
    Have you looked at this app note:
    http://www.keil.com/appnotes/docs/apnt_209.asp
    It will help you isolate what exactly is creating the fault
    When debugging, make sure to look at the system viewer windows, to make sure the clocks and GPIO pins are configured correctly:
    www.keil.com/.../uv4_db_dbg_systemviewer.htm
    good luck
  • It seems that you have quite an old system file for STM32F4 series.
    Latest system file from STM32F4 Device Family pack V2.13.0 (http://www.keil.com/dd2/pack/) has an updated SystemInit_ExtMemCtl() function.
    The RCC AHB1 clock register needs to be or-ed (not just overwritten).
    RCC->AHB1ENR |= 0x00000078;
    That should behave similar as when you have manually enabled the clocks in the register.
    I suggest you use the updated system file since it might solve also other potential issues.
  • Thanks for the help.
    I wasn't aware I could download the Keil family packs so last night I found newer versions of system_stm32f427x.c on GitHub.
    That got me past the hard fault and now the SDRAM is working for the first 8MB of 16MB available (accessing the top 8MB causes a hard fault) but I can also see occasional read errors when viewing the RAM contents under debug. The Github FMC setup is quite a bit different to the latest Keil family pack probably due to different SDRAMs used on different eval boards.
    I should now have enough to work with and I can tailor the code to suit my SDRAM.
    Thanks again for your help.
