I am working on Nucleo F103RBVT6 development board, In pack example, I didn't have USB device HID, MSD codes for F103RBVT6. I am unable to check the USB device functionality in the board. I need to develop the USB Custom class in Development board. Once I verified the HID or MSD then I will start custom class implementation.
Is there a USB custom class example project or HID/MSD for F103RBVT6?
Regards R.Dhanapal
The Nucleo board, and the STM32 chip on it, are ST products - not Keil.
So ST's site would be the place to be looking.
Start here: www.st.com/.../nucleo-f103rb.html for the board
And here: www.st.com/.../stm32f103rb.html for the chip
Hello Dhanapal,
It looks like this is the board you are talking about:
There are CMSIS-PACK examples for the STM32F103RB. Only certain devices have middleware drivers provided by their device manufactuerer. Fortunately, tis device is one of those:
http://www.keil.com/support/docs/3707.htm
To see a USB example for a STM32F103RB:
Open the Pack installer, C:\Keil_v5\uv4\PackInstaller.exe
- On the top left of the window, for "Search", type "STM32F103RB" - the list below gets filtered. - Select the device (entry with a green icon) from the list below – on the right side of the dialog updates with Software Packs relevant to this device - For "Packs", install the Keil:STM32f1xx_DFP pack (if necessary) - On the top right of the screen, select the yellow "Examples" tab. - On the "USB Device HID(MCBSTM32E)" row, click the "copy" button - a adialog pops up. - Pick a directory, click both the check boxes, and press OK - a new Keil µVision session opens with the example. - Build the project, Connect a USB cable to the board and start the debugger
See also - the Getting Started guide at http://www.keil.com/gsg - Learning page http://www.keil.com/learn - Creating applications at http://www.keil.com/support/man/docs/uv4/uv4_ca_packinstaller.htm
I see you asked about the custom class. You can read more about it here:
http://www.keil.com/pack/doc/mw/USB/html/_custom_class.html
There is example code in here:
www.keil.com/.../group__usbd__class_functions.html
I hope that helps
Hi Kevin,
The example is available for STM32F103ZG not for STM32F103RB If I change the target to STM32F103RB in Uvision then it is not working.
Regards R.Dhanapal.
that's entirely uninformative!
www.catb.org/.../smart-questions.html
What debugging / testing / investigation have you done?
Have you checked with the ST documentation to see what are the differences between STM32F103ZG and STM32F103RB ?
What, exactly, is "not working" ?
Have you looked on the ST pages for alternative examples?
