Everytime I try to build the project that I'm working on, I get the following error:
.\keil_output\periph_systick.axf: error: L6002U: Could not open file ..\..\..\..\..\..\software\lpc_core\lpc_board\boards_18xx\ngx_xplorer_1830\keil_output\core_m3\lib_lpc_board_ngx_xplorer_1830.lib: No such file or directory
I already checked the path aboe, and both .lib and folder exist. I tried to set the lib path manually on the "File extensions, books and enviroments" option but nothing changes. I'm out of ideas, any help is welcome.
Ps: I'm trying to buld the project to load into a LPC1837 board with a Cortex-M3.
http://www.keil.com/support/docs/3189.htm
But it's a relative path - isn't it?
So are you sure that you are starting from the correct place ... ?
After all, I found out that the problem was that the path, for some reason, was too long for windows recognize. Thanks for the help.
That's a common Windows problem, unfortunately.
