Hi, I know this problem has been discussed several times before. But my problem is little different. I am using latest version of Keil MDK(just downloaded) on Windows 7 professional, at a laptop having 1366 x 768 resolution. I tried my level best to follow all the advice given by posters in other threads. I followed the view changing from landscape to portrait method I followed the 100% font size method I followed clearing reg keys method I followed the start program as administrator method and reinstalled program for several times. I did every thing I read.
Whenever I am starting the program it displays initial starting windows along with a popup that says to either close the program of check online for solutions.
I cant buy a new laptop. Is there any work around?
Thanks and cheers
Tahir
Common guys, someone please help...
Who are you calling "common" ?!
Have you tried contacting Keil support?
:) Yes sir. And as you know...received no answer since past week. So, feeling helpless now.
btw the intention was to write Come on, but key board twist made it Common. :)
