program crashs in debugging and it doesn't run to main !!
linking... .\Objects\ELKREM.axf: Warning: L6776W: The debug frame in .debug_frame(spark_wiring_string.o) does not describe an executable section. Program Size: Code=230416 RO-data=58212 RW-data=1944 ZI-data=88032
can you help me , thanks in advance
Always good to start by just putting the error code into your favourite internet search engine:
community.arm.com/.../arm-linker-warning-l6776w
Hello Islam,
To best diagnose this issue, please contact support and open a ticket. They will be better equipped to diagnose the fault causes, rather than the Keil community.
Simple things you could try - Make sure you have the latest version of the tools. - Test if it is only a certain project that crashes, or all projects - In the Keil µVision IDE, select "project -> clean" and then "Window -> reset view to defaults, click restart" - Make sure your computer's antivirus is not causing issues.
relevant links
http://www.keil.com/support/man/docs/uv4/uv4_ui_project.htm http://www.keil.com/support/docs/3890.htm
As for the L6776W, it is safe to ignore. You can read more about it here:
http://www.keil.com/support/docs/4097.htm
Are you still having a crash? Are you sure you flashed the device correctly
