I finally upgraded from uVision4 to uVision5 and now I'm encountering a frequently reoccurring error when building. The errors are file sharing errors from my project folder, which happens to be a Microsoft OneDrive folder. I never had any issues with file sharing errors with projects in OneDrive folders while using uVision4.
Is anyone else experiencing this? Anyone know why this is happening, and how to fix it?
It's quite annoying, because my edits are not being saved. I've temporarily resorted to manually moving projects from OneDrive to a local drive (while working on them); but that's a pain because I have to copy everything back to OneDrive every so often, or at least when I'm done for the day.
Thanks.
Hello David,
In this forum thread:
http://www.keil.com/forum/63974/
They said:
MDK development team is working on a solution now. This "sharing violation" issue should be fixed in the next MDK release (newer than MDK v5.26))
... so I say you should create a support ticket for this issue, so that Keil Tech support can send you an updated version of the uv4.exe
That pre-release executable should fix your issues.
I did recently get a new UV4.exe file and have been using it for about a week now, and I have not seen the issue since using the new UV4.exe file.
