Dear Sir, I have a problem about the union and bitfiled. I always suffer a strange problem in my system. After I check the M51 file, I start to doubt that it is the bitfield and union problem in compile stage. please see my code as below, I declare the union and macros in header file.
Question: Please see the line 1198, I call the macro Drv_ClearRxEnd(). At C:0x1AE3, it calls the C:269D. At C:0x269E ANL A,#IRCON2(0xBF) I don't know why to use the SFR register(IRCON2) to clear it.
Could you give me some clues? Thank you.
In Header file: typedef union{ U8 u8IsrStatus; struct{ U8 cc_tx_start:1; //set by ISR, clear by SW //LSB U8 cc_tx_end:1; //set by ISR, clear by SW U8 busbusy:1; //set by ISR, clear by SW U8 HardResetSignaling:1; U8 CableResetSignaling:1; U8 cc_rx_start:1; //set by ISR, clear by SW U8 cc_rx_end:1; //set by ISR, clear by SW U8 pluginout:1; //set and clear by ISR //MSB }Bits; }ISR_STATUS; extern ISR_STATUS volatile sISR_Status; #define Drv_GetCableRst() (sISR_Status.Bits.CableResetSignaling) #define Drv_GetHardRst() (sISR_Status.Bits.HardResetSignaling) #define Drv_GetRxEnd() (sISR_Status.Bits.cc_rx_end) #define Drv_ClearRxStart() {sISR_Status.Bits.cc_rx_start=0;} #define Drv_ClearRxEnd() {sISR_Status.Bits.cc_rx_end=0;} #define Drv_ClearRxStart() {WRITE_SFR_REG(LCD_LN0_4,0xBB);WRITE_SFR_REG(LCD_LN0_4,0xBB);sISR_Status.Bits.cc_rx_start=0;WRITE_SFR_REG(LCD_LN0_4,0xBB);WRITE_SFR_REG(LCD_LN0_4,0xBB);} #define Drv_ClearRxEnd() {WRITE_SFR_REG(LCD_LN0_4,0xBC);WRITE_SFR_REG(LCD_LN0_4,0xBC);sISR_Status.Bits.cc_rx_end=0;WRITE_SFR_REG(LCD_LN0_4,0xBC);WRITE_SFR_REG(LCD_LN0_4,0xBC);} In M51 file: C:0x1A72 900368 MOV DPTR,#sISR_Status(0x0368) C:0x1A75 E0 MOVX A,@DPTR C:0x1A76 F5B4 MOV LCD_LN0_4(0xB4),A C:0x1A78 E0 MOVX A,@DPTR C:0x1A79 F5B4 MOV LCD_LN0_4(0xB4),A 1179: WRITE_SFR_REG(LCD_LN0_4,0xFD);WRITE_SFR_REG(LCD_LN0_4,0xFD); 1180: #endif 1181: 1182: C:0x1A7B 75B4FD MOV LCD_LN0_4(0xB4),#0xFD C:0x1A7E 75B4FD MOV LCD_LN0_4(0xB4),#0xFD 1183: if(Drv_GetRxEnd() && !Drv_GetHardRst() && !Drv_GetCableRst()) C:0x1A81 E0 MOVX A,@DPTR C:0x1A82 20E603 JB 0xE0.6,C:1A88 C:0x1A85 021C5F LJMP C:1C5F C:0x1A88 E0 MOVX A,@DPTR C:0x1A89 30E303 JNB 0xE0.3,C:1A8F C:0x1A8C 021C5F LJMP C:1C5F C:0x1A8F E0 MOVX A,@DPTR C:0x1A90 30E403 JNB 0xE0.4,C:1A96 C:0x1A93 021C5F LJMP C:1C5F 1184: { 1185: DEBUG_PRLRX(0xAF); 1186: 1187: #if PRINTF_MSG_HEADER_RX C:0x1A96 75B5AF MOV LCD_LN0_5(0xB5),#0xAF ......Omit....... 1198: Drv_ClearRxEnd(); C:0x1ADD 1226A1 LCALL L?0396(C:26A1) C:0x1AE0 900368 MOV DPTR,#sISR_Status(0x0368) C:0x1AE3 12269D LCALL L?0395(C:269D) 1199: Drv_ClearRxStart(); 1200: 1201: C:0x1AE6 75B4BB MOV LCD_LN0_4(0xB4),#S1RELH(0xBB) C:0x1AE9 75B4BB MOV LCD_LN0_4(0xB4),#S1RELH(0xBB) C:0x1AEC E0 MOVX A,@DPTR C:0x1AED 54DF ANL A,#0xDF C:0x1AEF F0 MOVX @DPTR,A C:0x1AF0 75B4BB MOV LCD_LN0_4(0xB4),#S1RELH(0xBB) C:0x1AF3 75B4BB MOV LCD_LN0_4(0xB4),#S1RELH(0xBB) C:0x26A1 75B4BC MOV LCD_LN0_4(0xB4),#0xBC C:0x26A4 75B4BC MOV LCD_LN0_4(0xB4),#0xBC C:0x26A7 22 RET C:0x269D E0 MOVX A,@DPTR C:0x269E 54BF ANL A,#IRCON2(0xBF) C:0x26A0 F0 MOVX @DPTR,A C:0x26A1 75B4BC MOV LCD_LN0_4(0xB4),#0xBC C:0x26A4 75B4BC MOV LCD_LN0_4(0xB4),#0xBC C:0x26A7 22 RET
It doesn't. The disassembler just referred to IRCON2 as a possible interpration of the raw value 0xBF. Whatever your undisclosed "strange problem" might be: this is has nothing to do with it.
