microchip saml11 example message error
Hi sir,
I want to batch build the example project of microchip "trustzone_nortos", but the messages appeared as follow.
File : D:\MDK525\ARM\PACK\Keil\SAML11_DFP\1.0.82\Keil.SAML11_DFP.pdsc
Sequence : ProgramBootImageHash
Context : Item #1: <control if="(BS_BootOpt > 0) && (BS_Length > 0)"> Item #4: <block>::Line 2
Expression : " BufferStreamIn(0, BS_HashAddr, 0x20, "$P/Boot_sha256.bin", 0, 0);"
E203 : Undefined identifier - function 'BufferStreamIn'
Context : Item #1: <control if="(BS_BootOpt > 0) && (BS_Length > 0)"> Item #5: <control while="PageAddr < (SectorAddr + SectorSize)"> Item #0: <block>::Line 4
Expression : " BufferWrite(0, PageAddr, PageAddr, 0x20, 32|1);"
E203 : Undefined identifier - function 'BufferWrite'
And a lot more like this.
I am using MDK5.25-pre.
What's wrong with it? And how can i avoid it?
Thanks!
  • The message tells you very clearly and explicitly what is wrong:
    "And how can i avoid it?"
    Define the identifier!
  • Hi Andrew Neil,
    I didn't feel good to your way of answer. It made me feel stupid somehow. Because you just said nothing to my problem. So, i want you to answer how would you define the identifier?
    In fact, I move to MDK6.26-pre and everything is OK.
  • So if you knew that, why didn't you say that?
    What have you done to find out where that identifier should have been defined?
    That identifier is clearly a function - so you are looking for a function definition.
    A function definition would normally be in either a .c source file, or a library.
    You would probably also expect it to have a declaration - ie, a prototype - in a .h header file.
    You say this is Microchip's code - so what does their documentation tell you?
    Did they supply it as complete, ready-to-build Keil project?
    Have you contacted them for support?
    "I want to batch build"
    What happens if you just do a conventional, interactive build - from the IDE?
