Hey everyone,
I am attempting to move an existing project from Atollic to Keil (as Atollic is no longer supported by my MCU).
All I want to do is add the appropriate headers and source files that have already been generated to my current Keil project.
I have already gone and found the header file I wish to implement, and I can see it very clearly under the Project pane on the left, however whenever I compile I get:
"Cannot open source input file "board.h": No such file or directory.
I have searched high and low for a tutorial explaining how to start a Keil program from scratch in order to make bin files, but nobody seems to be talking about it.
Can someone help me?
Make sure that the directory that contains board.h is in the list of directories to look for include files in.
Flash / Configure Flash Tools / C/C++ / Include Paths
The output pane of the project options allows you to create a .HEX (Intel) as well as the more usual .AXF (ELF) file.
You can use FromELF as a post-link user task in the user pane of the project options. www.keil.com/.../armutil_pge1362128877330.htm
ARM FromELF, 5.03 [Build 76] [MDK-ARM Lite] ARM image conversion utility fromelf [options] input_file Options: --help display this help screen --vsn display version information --output file the output file. (defaults to stdout for -text format) --nodebug do not put debug areas in the output image --nolinkview do not put sections in the output image Binary Output Formats: --bin Plain Binary --m32 Motorola 32 bit Hex --i32 Intel 32 bit Hex --vhx Byte Oriented Hex format --base addr Optionally set base address for m32,i32 Output Formats Requiring Debug Information --fieldoffsets Assembly Language Description of Structures/Classes --expandarrays Arrays inside and outside structures are expanded Other Output Formats: --elf ELF --text Text Information Flags for Text Information -v verbose -a print data addresses (For images built with debug) -c disassemble code -d print contents of data section -e print exception tables -g print debug tables -r print relocation information -s print symbol table -t print string table -y print dynamic segment contents -z print code and data size information Software supplied by: ARM Limited
I'm sure I could find video tutorials if I needed such things. More a books and manuals guy myself.
