memory
Hello
I Always used Atmel AT89C51RE2 but there the production stopped we changed over to
Silicon C8051F580 processor.
now I am facing problems with the memory.
when I add variables after downloading the program wont run.
the compiler give Program Size: data=78.3 xdata=172 code=10749
so to mine point there is enough space.
maybe something with parameters?
with regards
Jos
  • So where, exactly, is it hanging?
    And what, exactly, is the point at which it goes from "working" to "hanging"?
    Look at the instructions for posting source code: www.danlhenry.com/.../keil_code.png
  • you are missing the watchdog disable in startup
  • this is mine memory model
    //memory model for Titan
    //version:
    //date 02 march 2018
    #include "defines.h"
    #include "memory.h"
    signed char iPos = -1;                                  //pointer received data
    signed char xdata channel=0;
    signed char xdata Address;
    signed char xdata iMessLen=0;
    unsigned char idata hexstring[8];
    unsigned char xdata Uart_Buffer_Pointer = 0;
    //unsigned char xdata Uart[Uart_Buffer_In_Size];
    unsigned char xdata rMessage[Uart_Buffer_In_Size];                              // data for processcom
    unsigned char xdata sMessage[Uart_Buffer_Out_Size];                     // data for Sendbuffer
    unsigned char xdata LMessage[Uart_Log_Output];
    unsigned char idata Uart_Tx_Index;
    unsigned char idata Uart_Tx_SendLen;
    unsigned char idata mem[0x10];
    unsigned char idata CalData[0x10];
    unsigned char idata ScheduledKanalen=0x00;   // Mask of kanalen used in scheduling
    unsigned char idata MeasuredKanalen=0x00;    // Mask of kanalen measured since last readout
    signed int xdata Kanalen[NUMANAIN] = {-32768,-32768,-32768,-32768};
    unsigned char xdata Dig[2];                // Control for digital in and out
    unsigned char LRCResult();
    unsigned char xdata ucLRC;
    //clock
    //signed int date=0;
    long idata seconds=0;
    long idata longvalue=0;
    //datalogging
    bit memory_overwrite_flag = 0;
    bit memory_overflow_flag = 0;
    bit setlogging_flag =0;
    bit forced_logging_flag =0;
    bit setmask_flag = 0;
    //uart
    bit uart_rx_valid=0;                                            //data received valid
    bit uart_tx_flag=0;                                             //data transmitted valid
    bit ti_1_busy;
    bit rx_valid;
    bit sendserialnumber;
    bit TX_Ready =0;
    struct TimeProfile idata Tprofile;
    struct LogProfile idata Lprofile;
    this is the start of mine program
    SFRPAGE = ACTIVE_PAGE; PCA0MD &= ~0x40; // Disable watchdog timer
    PORT_Init(); // Initialize Port I/O
    SYSCLK_Init (); // Initialize Oscillator
    TIMER0_Init (); // Initialize Timer0
    TIMER2_Init (); // Initialize Timer2
    SPI0_Init ();
    UART0_Init (); // Initialize UART LED_1 = OFF;
    LED_2 = OFF; LED_3 = OFF; //SFRPAGE = ACTIVE2_PAGE; //disabling this line will activate wd but out of control EA = 1;
    RX_EN = OFF;
    TX_EN = OFF;
    readcaldata();
    ADC_Init();
    Watchdog_Init ();
    if ((RSTSRC & 0x02) == 0x00) // First check the PORSF bit. if PORSF
    { // is set, all other RSTSRC flags are // invalid // Check if the last reset was due to the Watch Dog Timer if (RSTSRC == 0x08) { EA = 1; // Enable global interrupts } } // Calculate Watchdog Timer Timeout
    // Offset calculated in PCA clocks
    // Offset = ( 256 x PCA0CPL5 ) + 256 - PCA0L
    // = ( 256 x 255(0xFF)) + 256 - 0
    // Time = Offset * (12/SYSCLK)
    // = 255 ms ( PCA uses SYSCLK/12 as its clock source) PCA0MD &= ~0x40; // Disable watchdog timer
    PCA0L = 0x00; // Set lower byte of PCA counter to 0
    PCA0H = 0x00; // Set higher byte of PCA counter to 0
    PCA0CPL5 = 0xFF; // Write offset for the WDT
    PCA0MD |= 0x40; // Enable the WDT watchdog still not working well EA = 1; // Enable global interrupts </prev> Also I use the standard startupfile from Keil/Silicon
  • who cares about your memory model, your problem is not disabling the WD in startup
  • and it's incomplete, anyhow; eg, where are the array size definitions?
    Not sure that this would generally be called a "memory model" - it's just a list of (presumably global?) variables.
  • Note that this was the very first reply given to your cross-post on the SiLabs forum:
    www.silabs.com/.../hello_i_am_jos-5BRm
    Thus showing the importance of keeping up-to-date with all the threads if you're going to cross-post the same questions to multiple places!
    Be sure to go back and thank 'delu' on the SiLabs forum ...
