I'm considering a BT module with my stm32f205. Was thinking maybe the 0c-05 will do the job. I was wondering if keil had a middle package for bt? Also is BT and USB code interchangeable in any way? We already have the USB code set up with control transfers and its report descriptor. I know BT is for the most part the same thing. Any easy way to just add BT to an existing USB project?
No.
"I know BT is for the most part the same thing"
Do you?
How do you make that out??
"I was wondering if keil had a middle package for bt?"
did you try checking: www2.keil.com/.../middleware ?
obdgenie obdgenie,
You are one smart cookie and you obviously know more than anyone here. I don't understand why you ask for advice from anybody.
