We are migrating the IAR based STR91XX(ARM9)project to Keil environment.
I could see __iar_data_init, some system predefined function (not sure what it do). Might be some data initialization. What is it's equivalent replaceable pre-defined function in Keil environment.
Used in following scenario as part of start of program start:
EXTERN __iar_data_init ------ ---- LDR r0,= __iar_data_init ------ -------
Regards, Siva
