i have to move to a new Laptop. I have a license for C51 V9.50a.
Is it possible to run the c51 V9.50a with MDK5.25? Where can a download the C51V950a.exe file?
Best regards, Roman Missler
See the reply here: http://www.keil.com/forum/63678/
Did you not keep your original installation file?
Ive got c51 but i must use older version can i use the old key lisense if it is newer.
What comnd paremeter for mdkarm work in c51 mode.
Ive got c51 but i must use older version can i use the old key lisense if it is newer. you can use it on any version if it is current, if not on no version What comnd paremeter for mdkarm work in c51 mode. a totally different product MDK_ARM does ARM, C51 does the ,51 C166.... they all use uVision as the IDE but the rest is totally different and they must be purchased separately.
there are free versions e.g. MDK-ARM for ST cortex M0 and c51 for SiLabs chips
... should be discussed direct with Keil (or your local distributor).
The 'Contact' link is at the foot of every page
