Hello ,
I am interfacing SD card on ARM: LPC3250, able to read and write in both RAW and DMA mode(Using chan's Fatfs library).
facing issue on: New file writing with data more than 512 bytes (but works well on writing 512 bytes) . If data >512 bytes return DataCrcFail status bit 1 i.e CRC check failed on fclose() (Updating Fat table 1 about new file it fails).
Please help/suggest sd card writing using RAW DMA samples if any.
Thank you
