I am having trouble changing from a Texas Instruments TM4C123 to TM4C129 that are Arm Cortex-M4
In Texas Instruments "Tivaware" many libraries which have something like: #if defined(TARGET_IS_TM4C123_RA1) #define ROM_SysCtlClockSet ((void (*)(uint32_t ui32Config))ROM_SYSCTLTABLE[23]) .... I know that the "TARGET_IS_TM4C123_RB1" is currently defined (by testing to see which #if is actually completing). Yet, "TARGET_IS_TM4C129_RA1" should be defined. Then, I believe the preprocessor will start parsing and substituting correctly.
Where in a Keil project is a particular "TARGET_IS_xyz" defined?
-In "Device" of flash config tools I have selected TM4C129NCPDT which is correct to chip. -I am using JTAG over J-Link Segger -Keil MDK-Lite Version 5.24.1
It's in 'Define' under 'Preprocessor Symbols' - here:
http://www.keil.com/support/man/docs/uv4/uv4_dg_adscc.htm
Thank you! Not sure I am out of the woods. But that was a major help.
