Hi, I want to connect a Keypad 4 × 4 to the Lpc 23xx . I used the LCD_4bit code and after pressing the button, the character want on the LCD displayed But it doesn't Work.
Pin description for Keypad: ( Raws: P0.8 and P0.9, P0.10, P0.11 - Columns:P0.12 and P0.13, P0.14, P0.15)
This is my C Cod:
#include <LPC23xx.H> #include "lcd.h" #include "keypad.h" /******************************************************************************* * PUBLIC FUNCTION: c_read_keypad * * PARAMETERS: * ~ void * * RETURN: * ~ numeric value for the pressed key. Return 0xFF if no key is pressed. * * DESCRIPTIONS: * Read from the keypad. * *******************************************************************************/ unsigned char keypad_read(void) { //start the scanning process KP_R1 = 0; // scan keypress on 1st row: 1, 2, 3, A KP_R2 = 1; KP_R3 = 1; KP_R4 = 1; __delay_us(30); if (KP_C1 == 0) return '1'; // Key '1' is pressed if (KP_C2 == 0) return '2'; // Key '2' is pressed if (KP_C3 == 0) return '3'; // Key '3' is pressed if (KP_C4 == 0) return 'A'; // Key 'A' is pressed, we will store as 10 KP_R1 = 1; // scan keypress on 2nd row: 4, 5, 6, B KP_R2 = 0; KP_R3 = 1; KP_R4 = 1; __delay_us(30); if (KP_C1 == 0) return '4'; // Key '4' is pressed if (KP_C2 == 0) return '5'; // Key '5' is pressed if (KP_C3 == 0) return '6'; // Key '6' is pressed if (KP_C4 == 0) return 'B'; // Key 'B' is pressed, we will store as 11 KP_R1 = 1; // scan keypress on 3rd row: 7, 8, 9, C KP_R2 = 1; KP_R3 = 0; KP_R4 = 1; __delay_us(30); if (KP_C1 == 0) return '7'; // Key '7' is pressed if (KP_C2 == 0) return '8'; // Key '8' is pressed if (KP_C3 == 0) return '9'; // Key '9' is pressed if (KP_C4 == 0) return 'C'; // Key 'C' is pressed, we will store as 12 KP_R1 = 1; // scan keypress on 4th row: *, 0, #, D KP_R2 = 1; KP_R3 = 1; KP_R4 = 0; __delay_us(30); if (KP_C1 == 0) return '*'; // Key '*' is pressed, we will store as 14 if (KP_C2 == 0) return '0'; // Key '0' is pressed if (KP_C3 == 0) return '#'; // Key '#' is pressed, we will store as 15 if (KP_C4 == 0) return 'D'; // Key 'D' is pressed, we will store as 13 return 0xFF; // if no key press, the register is 0xFF } /******************************************************************************* * PUBLIC FUNCTION: c_wait_keypad * * * DESCRIPTIONS: * Wait until the key is pressed and released. * *******************************************************************************/ unsigned char keypad_wait(void) { // The pressed key. unsigned char c_pressed_key = 0xFF; // Wait until the key is pressed. do { c_pressed_key = keypad_read(); } while (c_pressed_key == 0xFF); // Wait until the key is released. while (keypad_read() != 0xFF); return c_pressed_key; }
