I am able to load and run board specific example code with no errors.
However I am receiving errors when trying to load examples from the CMSIS-Compliant Standard Peripheral Firmware Driver Library. The code is able to compile, but when trying to load the code the following error appears:
"--- Error: failed to execute '"" '".
Would anyone know a fix for this error?
Make sure you've selected the right debugger (make/model), that it has the right settings (jtag/swd), and that the correct flash algorithm has been picked.
Look at the project/debugger settings in the context of the ones that are working, and how they differ to the ones that aren't
Thank you for the help, all working now.
