Hey ARM/Keil Team,
I have been using keil mdk with evaluation board of LPC2148 for testing and training purposes but unable to get any info to use RAM so program goes in RAM and works from there. i want to use RAM & ROM both,so when i program the RAM, program will run in RAM till the power is on in EVB, and as soon as cable is removed and power goes off, ROM flashed program should work normally as RAM after power off should be released from that code written into it.
Please help.
Best Regards, Kushang
