Hi, I found a problem using multi-target in a project.
If I create 2 targets,and 1. in [Options for Target 'Target 1'] define APP1 in preprocessor symbols 2. in [Options for Target 'Target 2'] define APP2 in preprocessor symbols
and there is a c file in the project like:
version.c
#ifdef APP1 const uint8_t Version[]="00000001"; #elif defined APP2 const uint8_t Version[]="00000002"; #endif
Now if I build target1, and switch to target 2,then build this target using 'Bulid(F7)',the version.c will not be rebuild. So in the output HEX file, I can see the data of 'Version' is still "00000001".
After that I found if I use 'Rebuild' command,the output HEX file will be updated. But rebuild all takes too much time.
Is it a bug or not?
The file hasn't changed. Consider
#ifdef APP1 #include "app1.h" #elif defined APP2 #include "app2.h" #endif
app1.h
app2.h
That indicates you didn't really put enough work into defining those two targets as separate entities. Most importantly, you really should not have them configured to be using the same folder for their object files. I.e. you should have two "version.obj" files, in different places, so one cannot accidentally be mistaken for the other.
E how to fo it
