Among other .c files, my code has one (less then 1kb) which I would like to place at some predetermined location in my ARN CPU flash. That file is in fact consisted mostly of constant data. Is there some way to achieve such goal and if yes, how ? I am new to ARM and came from C51 world, where I already did the above-like work, by the help of linker directives. I am using MDK Keil v4.
AT directive, or attribute pointing to specifically crafted load region. Check/create scatter file
Because scatter file is something new to me (I just made a glance to it) I am interested how should I tell to IDE to take into account edited version of that file ? Do I have to call linker separately, from command line with that new scatter file ?
http://www.keil.com/support/man/docs/uv4/uv4_dg_adsld.htm
