Unable to flash the STM32L151CC
We are trying to run application code on the STM32L151CC starting at 0x08008000. Part of the job of the code is to write to a flash area starting at 0x08024000, but the code freezes when we try this, and the debugger stops working.
The problem appears to be in HAL_FLASHEx_HalfPageProgram. If we comment out the line *(__IO uint32_t*) ((uint32_t)(Address + (4 * count))) = *(pBuffer++); the rest of the code will run fine (without actually flashing of course).
If our application code runs from 0x08000000 there is no problem.
Steve
  • I should add that the same code runs correctly on the STM32L151VE, except the flash area is moved to 0x08040000. HAL_FLASHEx_HalfPageProgram is in SRAM in both cases.
  • Try version 1.7.0.
    Correction is:
        /* Wait for last operation to be completed */
        status = FLASHRAM_WaitForLastOperation(FLASH_TIMEOUT_VALUE);
        /* Enable IRQs */
        __enable_irq();
    instead of:
        /* Enable IRQs */
        __enable_irq();
