Bare Metal Criical Section Code for Cortex MO
On a bare metal system you often need to protect code with a critical section.
Here is an article describing what I need.
mcuoneclipse.com/.../
At the end, the author provides an example. Try as I might, I cannot get this or variants to compile with KEIL. Can anyone help? I am looking for the solution to work with C++.
Rich
Here are the specifics on the KEIL tool that I am using.
IDE-Version:
µVision V5.22.0.0
Tool Version Numbers:
Toolchain: MDK-Lite Version: 5.22
Toolchain Path: C:\Keil_v5\ARM\ARMCC\Bin
C Compiler: Armcc.exe V5.06 update 4 (build 422)
Assembler: Armasm.exe V5.06 update 4 (build 422)
Linker/Locator: ArmLink.exe V5.06 update 4 (build 422)
Library Manager: ArmAr.exe V5.06 update 4 (build 422)
Hex Converter: FromElf.exe V5.06 update 4 (build 422)
CPU DLL: SARMCM3.DLL V5.22
Dialog DLL: DARMCM1.DLL V1.15.0.0
Target DLL: UL2CM3.DLL V1.159.0.0
Dialog DLL: TARMCM1.DLL V1.11.0.0
Code:
#define CpuCriticalVar()  uint8_t cpuSR
#define CpuEnterCritical()              \
  do {                                  \
    asm (                               \
    "MRS   R0, PRIMASK\n\t"             \
    "CPSID I\n\t"                       \
    "STRB R0, %[output]"                \
    : [output] "=m" (cpuSR) :: "r0");   \
  } while(0)
#define CpuExitCritical()               \
  do{                                   \
    asm (                               \
    "ldrb r0, %[input]\n\t"             \
    "msr PRIMASK,r0;\n\t"               \
    ::[input] "m" (cpuSR) : "r0");      \
  } while(0)
Test code
#if 0 /* original, buggy version */
  #define DEFINE_CRITICAL() /* nothing */
  #define ENTER_CRITICAL()  EnterCritical()
  #define EXIT_CRITICAL()   ExitCritical()
#else /* fixed version using local variable */
  #define DEFINE_CRITICAL() CpuCriticalVar()
  #define ENTER_CRITICAL()  CpuEnterCritical()
  #define EXIT_CRITICAL()   CpuExitCritical()
#endif
static volatile uint8_t shared=0;
static void Error(void) {
 for(;;);
void T1(void) { /* called by timer interrupt every 0.1 ms, max prio (0) */
 DEFINE_CRITICAL();
 ENTER_CRITICAL();
 shared += 1;
 if (shared!=1) {
 Error();
 shared -= 1;
 EXIT_CRITICAL();
void T2(void) { /* called by timer interrupt every 1 ms, minimal prio (3) */
 DEFINE_CRITICAL();
 ENTER_CRITICAL();
 shared += 1;
 if (shared!=1) {
 Error();
 shared -= 1;
 EXIT_CRITICAL();
static void test(void) {
 DEFINE_CRITICAL();
 for(;;) {
 ENTER_CRITICAL();
 shared += 1;
 if (shared!=1) {
 Error();
 shared -= 1;
 EXIT_CRITICAL();
