EFS fopen in read mode wont work
I am using a SPI NOR Flash (AT45DB641E) with Keil MDK5 Flash File System v6.8 and EFS.
Init, Mounting and formatting works. Even "finfo()" works an delivers information about FS and overall flash size of 8MB.
But creating a file and then re-open it in read mode doesnt work. Like shown in this snippet:
file = fopen("reinhard.keil","w"); // open file in write mode
if(file != NULL)
   printf("Success: created \"reinhard.keil\" \r\n");  // this works!
if(fputs("This is an example for fputs.\n", file) >=0) // write a string to file
   printf("Success: wrote string to file \"reinhard.keil\" \r\n"); // this works too!
if(fclose(file)==NULL) // close file
   printf("Success: file \"reinhard.keil\" closed\r\n"); // this also works!
file = fopen("reinhard.keil","r");    // (re)open file in read mode
if(file == NULL)
   printf("Error: failed to re-open \"reinhard.keil\" \r\n"); // Hmmm, why is that?
   fsStat = ffind("reinhard.keil", &fsFileInfo); // lets look for this file
   if(fsStat != fsOK)
      printf("Can't find file"); // file still not present
What am i doing wrong? I already worked with Keil FS, but with SD-Card and FAT32...and it was doing well. Am I missing something with EFS? I know about the EFS-limitations, but I think I avoided them.
  • Are you sure that your SPI driver is functioning fine?
  • The reason why I am using Keil FS, is that the whole chain SPI-driver -> flash driver -> File System is working (theoretically) out of the box. I initialized with all the default settings. Since I am using SPI2 all I have changed is the value DRIVER_SPI_NUM from 1 to 2 in the file AT45DB641E.c.
    I think, if somethings is wrong with this lowest driver in stack, i couldn't have done the init of flash nor the mounting in file system. But they run smoothly with the return ARM_DRIVER_OK and fsOK.
    The only uncertainty I have with SPI driver is the NSS (CS) Pin. In RTE_Device.h I assigned SPI2-NS-Pin to PB9. If I leave it unassigned the function drv_flash->PowerControl(ARM_POWER_FULL) will return ARM_DRIVER_ERROR. But for real I have on my prototype PCB the CS to the Flash-IC on PD4 (PB9 is open). So I initialized PD4 GPIO manually as Out-PP and set it to low. Since then all inits ran without errors. And finfo() also delivers correct information.
    I really don't get what I am missing here.
  • Solved:
    The hint "Are you sure that your SPI driver is functioning fine?" was after all the right one. As I wrote: In RTE_Device.h I assigned SPI2-NSS-Pin to PB9. But it is possible to edit the RTE_Device.h in the way, that I can now select the PD4-GPIO in the Dropout-Menu. So the SPI-Driver now gets the right NSS/CS Pin and the Flash-Driver will toggle it automatically as it is meant to.
    BUT: it was confusing to not get any Error-Return from the Keil Flash-Driver or the File System. In previous versions it was possible the use File System with Debug option and the Compiler DAP Event Messaging (selected in the "Manage Run-Time-Environment" under "LFN Debug"). But this option is not present in Middleware V7.2
