Hi, I am doing a project on LPC2129 that needs LCD display. Where can I find the LCD peripheral or simulation in uVision 4 . I found a link which says to use System viewer file field. But "System Viewer File" field is not found. Please help me to find LCD simulation in uVision 4
with regards Vaishak
What, exactly, do you expect from this "LCD simulation" ?
Where in any Keil documentation have you seen it suggested that this is available?
Connect your physical display to your physical board. Code. Download. Test. That has worked well for several generations of developers - are you different?
