GUI_CM3_L.lib and Network
I am trying to use network into an application where I use without troubles GUI libraries but it seems they reserve same memory addresses or anyway it happens some kind of memory conflict: when calling GUI_Glear() I fall into HardFault_Handler. Tried to reserve for them different memory buffers modifying .sct file, specially regarding onChip SRAM zone but found no way to get out from this hanging. Some help? Thanks.
  • Sorry guys..., I was speaking about LPC178x/7x...
  • I have gone deeper in the problem and it seems due to IAP mechanism.
    I have some local variables that are allocated always in external memory even though I write in scatter file different instructions.
    For instance, taken from protected EMAC_LPC17xx.c file:
    static int32_t Initialize (ARM_ETH_MAC_SignalEvent_t cb_event) { uint32_t pb[2]; bool dev_175x;
    #if defined (LPC177x_8x) uint32_t cfg_val;
    #endif
    if (emac.flags & EMAC_FLAG_INIT) { return ARM_DRIVER_OK; }
    /* Read device ID with IAP */ pb[0] = 54; iap_entry (&pb[0], &pb[0]);
    After last instruction I fall in a memory/hardware fault becuase, I think, pb is in external memory. I tried to write many different solution in scatter file, for instance this one:
    RW_IRAM2 0x20001000 0x00005000 { ; RW data EMAC_LPC17xx.o (+ZI +RW) EMAC_LPC17xx.o (STACK) }
  • So the main questions are:
    - why local variables are allocated in ext RAM?
    - how to put local variables in IRAM?
    If someone has answers I will apreciate, thanks.
  • does the map file give you any clues?
  • Regarding the above mentioned file I find in .map file:
    Execution Region RW_IRAM2 (Base: 0x20001000, Size: 0x00002a8c, Max: 0x00005000, ABSOLUTE)
    Base Addr Size Type Attr Idx E Section Name Object
    0x20001000 0x00000018 Data RW 1225 .data emac_lpc17xx.o 0x20001018 0x00002a74 Zero RW 1223 .bss emac_lpc17xx.o
    that is what I asked but with the exception of local variables (in stack region I suppose).
    I fear the task stacks locations are decided by some rtx module, I try to explore in this direction.
