hello everyone
i'm facing problem with using function netif_Setoption and netif_Getoption to set the IP address for DHCP server. can anyone explain how to implement DHCP server using the CMSIS driver.
where is the DHCPnotify callback gets called. in which file the DHCPnotify gets called. so that i can take right action. once the interrupt is comes.
i'm following the steps as explain in the following link.
www.keil.com/.../network_create_app.html
after following the steps. i'm was not able to see the changed ip address.
You can take any network related example projects from the Pack Installer as a reference
Thank you for your response,
i have alright followed the example. but still i'm facing the problems.
