USB Communication in AT89C5131A
I have been trying to perform USB communication between my AT89C5131A chip and pyUSB, to transmit some data to the microcontroller.
I haven't been able to find any library which will help me achieve this and as a result I've been trying to understand the USB configuration mentioned in http://www.keil.com/dd/docs/datashts/atmel/at89c5131_ds.pdf.
On running the command dev.set_configuration(), I receive an error and I suppose this indicates a mistake in my configuration till that point.
My hardware bootloader however successfully runs with the dfu-programmer.
I've set the clock frequency correctly and enabled USBEN and FEN as mentioned.
1. Where am I going wrong?
2. Are there any good libraries for doing USB communication with AT89C5131A?
3. Should I switch to an AVR uC instead and use the LUFA library?
Thank you!
  • For AT89C5131A, Atmel has released a couple of USB device projects on Keil C51 on their website. This CDC implementation gives good starting point for your purpose.
    USB Communication Device Class - Migration from RS-232 to USB
    www.atmel.com/.../doc4322.pdf
    www.atmel.com/.../c5131-usb-cdc-1_2_1.zip
    You'll modify this example step by step.
    1) run this example on your board
    - This example supposes a 16MHz crystal. Tune it for your crystal
    config.h
    #define FOSC                    16000
    Your board should appear as a CDC device on your PC.
    2) Implement a loop-back, to test it on PC terminal.
    if ( uart_usb_tx_ready() && uart_usb_test_hit() ) {
       char c = uart_usb_getchar();
       uart_usb_putchar( &c );
    3) Replace the config descriptor into vendor-specific one, also VID/PID
    config.h
    #define DEVICE_CLASS          0x02  <-- 0xFF (vendor)
    #define VENDOR_ID             0xEB03        /* Atmel vendor ID = 03EBh */
    #define PRODUCT_ID            0x0920        /* Product ID: 2009h = CDC C5131 */
    #define CONF_LENGTH           0x4300  <-- 0x2000
    #define NB_INTERFACE          2       <-- 1
    #define INTERFACE1_NB          1      <-- 0
    #define INTERFACE1_CLASS       0x0A /* CDC ACM Data */  <-- 0xFF (vendor)
    usb_cdc_enum.c
    code struct
    { struct usb_st_configuration_descriptor  cfg;
      struct usb_st_interface_descriptor      ifc1;
      struct usb_st_endpoint_descriptor       ep1 ;
      struct usb_st_endpoint_descriptor       ep2 ;
      usb_configuration =
        { 9, CONFIGURATION, CONF_LENGTH, NB_INTERFACE, CONF_NB,
          CONF_INDEX, CONF_ATTRIBUTES, MAX_POWER},
        { 9, INTERFACE, INTERFACE1_NB, ALTERNATE1, NB_ENDPOINT1, INTERFACE1_CLASS,
          INTERFACE1_SUB_CLASS, INTERFACE1_PROTOCOL, INTERFACE1_INDEX },
        { 7, ENDPOINT, ENDPOINT_NB_1, EP_ATTRIBUTES_1, EP_SIZE_1, EP_INTERVAL_1 },
        { 7, ENDPOINT, ENDPOINT_NB_2, EP_ATTRIBUTES_2, EP_SIZE_2, EP_INTERVAL_2 },
    Now that pyusb is able to see this device.
    4) Lastly, clean up the source code.
    Tsuneo
  • Hey Tsuneo,
    Thank you for the informative reply. Unfortunately, I'm running the evaluation version of Keil uVision 4 and I'm getting a code size limit when I try to edit and compile the USB CDC project by Atmel. What's the best workaround here?
    Is there some other compiler (like SDCC) which will work here?
    Thanks,
    Kalpesh Krishna
  • Hey Tsuneo,
    I overcame the previous problem by using a PC having the full license. I successfully detected my device as a CDC device in pyusb.
    However, I'm a bit unsure about step 2. I added something like this to my main()
    while(1) {
          uart_usb_putchar(c);
    Is this the correct place to write this code? On running this with pyusb, I get the following :- (131 is the endpoint address)
    >>> dev.write(131, msg, 1)
    Traceback (most recent call last):
      File "<stdin>", line 1, in <module>
      File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 870, in write
        intf, ep = self._ctx.setup_request(self, endpoint)
      File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 190, in setup_request
        self.managed_claim_interface(device, intf)
      File "/usr/local/lib/python2.7/dist-packages/usb/core.py", line 146, in managed_claim_interface
        self.backend.claim_interface(self.handle, i)
      File "/usr/local/lib/python2.7/dist-packages/usb/backend/libusb1.py", line 747, in claim_interface
        _check(self.lib.libusb_claim_interface(dev_handle.handle, intf))
      File "/usr/local/lib/python2.7/dist-packages/usb/backend/libusb1.py", line 552, in _check
        raise USBError(_strerror(ret), ret, _libusb_errno[ret])
    usb.core.USBError: [Errno 16] Resource busy
    Which is the correct place to put the code for step 2)? What are some good resources to learn the USB protocol from?
    Thank you,
    Kalpesh
  • Dear Tsuneo,
    We were successfully able to transfer data to and from the microncontroller using pyserial. I think this code will be a great starting point for our application. Thanks for all the help!
