Creating project from import xml
I am trying to import an xml for enabling a pre-processor define in the project but it fails.
I dont see any error on the commandline, but the build also does not run.
XML file contents:
<?xml version="1.0" encoding="UTF-8" standalone="no" ?>
<Project>
  <CDefines>ARM_MATH_ENABLE</CDefines>
</Project>
Command used:
UV4.exe -b <Project filename> -i <xml_filename>
Any help for above or inputs to enable a pre-processor directive from command line is appreciated.
