Hello, I'm using µVision V5.15, with ARM 0. And with stopping the debuging, the "Startup_xxx.s" is always the active window in the Editor. Is it possible to hide this window ?
Thank you.
Dirk
What is "ARM 0" ?
Do you mean Cortex M0 ?
Well the debug starts at startup file but is it such a big problem to close this file ?
Hello, no it is not a problem to Close this file. But sometimes I write something into this file and with the next Compiler run, I will get some error messages.
Then may be you can be little more careful in what you are editing or typing in a file
What happens if you write-protect the file?
Exactly so. I remember one guy who everyone thought was a stunningly fast typist, but when one looked at what he was doing, he was backspacing and correcting more that he was in reality producing.
"Haste maketh waste"
In Edit->Configuration->Other check "Do not open matching souce file after Run Stop"
