Using coverage with µVision and 8051XC2 IP core with disabled Debug Onchip option
Hello, i need to know if certain options of Keil µVision could be used with a R8051XC2 IP core embedded in a Microsemi RT3PE FPGA, in which the On chip debug Option has been disabled ( Otherwise the model would not have been able to be contained by the FPGA.)
I would like to know if in this configuration it is possible to use i/the code coverage functionnality of Keil µVision4. ii/ the Keil simulator functionnality
Thanks for your answers, Raphaël Penet.
0
