hello i am trying to make a simple program . i want to make edge interrupt with pin PF4 in the tive-c launchpad (cortex m4) and when i press that button the led blinks . thats all but i am facing problems i dont know whats wrong but the program is not working as expected
#include "C:\Keil\ARM\INC\TI\TM4C123\TM4C123GH6PM.h" void delayMs(int n); int main(void) { SYSCTL->RCGCGPIO |= 0x20; /* enable clock to PORTF */ /* PORTF0 has special function, need to unlock to modify */ GPIOF->LOCK = 0x4C4F434B; /* unlock commit register */ GPIOF->LOCK = 0; /* lock commit register */ /* configure PORTF for switch input and LED output */ GPIOF->DIR &= ~0x11; /* make PORTF4 input for switch */ GPIOF->DIR |= 0x0E; /* make PORTF3, 2, 1 output for LEDs */ GPIOF->DEN |= 0x1F; /* make PORTF4-0 digital pins */ GPIOF->PUR |= 0x11; /* enable pull up for PORTF4, 0 */ /* configure PORTF4, 0 for falling edge trigger interrupt */ GPIOF->IS &= ~0x11; /* make bit 4, 0 edge sensitive */ GPIOF->IBE &= ~0x11; /* trigger is controlled by IEV */ GPIOF->IEV &= ~0x11; /* falling edge trigger */ GPIOF->ICR |= 0x11; /* clear any prior interrupt */ GPIOF->IM |= 0x11; /* unmask interrupt */ /* enable interrupt in NVIC and set priority to 3 */ NVIC->IP[30] = 3 << 5; /* set interrupt priority to 3 */ NVIC->ISER[0] |= 0x40000000; /* enable IRQ30 (D30 of ISER[0]) */ __enable_irq(); /* global enable IRQs */ /* toggle the red LED (PF1) continuously */ while(1) { GPIOF->DATA |= 0x02; delayMs(500); GPIOF->DATA &= ~0x02; delayMs(500); } } /* SW1 is connected to PF4 pin, SW2 is connected to PF0. */ /* Both of them trigger PORTF interrupt */ void GPIOF_Handler(void) { int i; volatile int readback; /* toggle green LED (PF3) three times */ for (i = 0; i < 3; i++) { GPIOF->DATA |= 0x08; //delayMs(500); GPIOF->DATA &= ~0x08; //delayMs(500); } GPIOF->ICR |= 0x11; /* clear the interrupt flag before return */ readback = GPIOF->ICR; /* a read to force clearing of interrupt flag */ } /* delay n milliseconds (16 MHz CPU clock) */ void delayMs(int n) { int i, j; for(i = 0 ; i < n; i++) for(j = 0; j < 3180; j++) {} /* do nothing for 1 ms */ } /* This function is called by the startup assembly code to perform system specific initialization tasks. */ void SystemInit(void) { __disable_irq(); /* disable all IRQs */ /* Grant coprocessor access */ /* This is required since TM4C123G has a floating point coprocessor */ SCB->CPACR |= 0x00F00000; }
thanks in advance
