i wrote a code for uart3 but the data was not receiving ,i checked all pheripherals like power control and pinsel regsistery and baudrate too, here i posted my code please do the needfull as soon as possible.
#include <LPC23xx.H>
unsigned int data;
/********************************INTI UART0**********************************************/ void Init_Uart0(void) { PINSEL0 |= 0x00000050; //UART0 CCLKCFG = 0x05; PCONP |= 0X08; //Powerup for UART0 // PINSEL0=0X050; //ENABLE UART0 U0FCR =0x07; //Fifo Enable U0LCR=3|(1<<7); //ENABLE DLAB AND 8-BIT CHARACTER LENGTH U0DLL=0X4E; //SET BAUD RATE =9600 FOR 12MHZ U0LCR&=0X0F; //DISABLE DLAB }
/********************************INTI UART3**********************************************/ void init_uart3(void) { PINSEL1 |= 0x003C0000; //UART3 CCLKCFG = 0x05; PCONP |= 0X02000000; //Powerup for UART3 U3FCR =0x07; //Fifo Enable U3LCR=3|(1<<7); //ENABLE DLAB AND 8-BIT CHARACTER LENGTH U3DLL=0X4E; //SET BAUD RATE =9600 FOR 12MHZ U3LCR&=0X0F; //DISABLE DLAB U3IER = 0X0; U3FCR = 0xc1; //Fifo Enable } /********************************************************************************************************/ void receive_uart0(void)
{ while(!(U0LSR &0x01)); data=U0RBR; }
/********************************************************************************************************/ void transmit_uart0(int data) { while(!(U0LSR &0x60)); U0THR =data;
void receive_uart(void) { while(!(U3LSR &0X01)); data=U3RBR; }
void transmit_uart(int data) { while(!(U3THR&0X60)); U0THR=data; }
int main() { init_uart3(); Init_Uart0(); receive_uart0(); transmit_uart0(data);
receive_uart(); transmit_uart(data); }
