Interrupt on Nuvoton NUC100LD2DN
Hi, I'm newbie on keil & I'm trying learn ARM Cortex-M0 from Nuvoton. I confuse how to use interrupt on timer funtion. How i can get interrupt from overflow? I'm familiar before with AVR, on atmel studio for interrupt I just call function
 ISR(TIMER1_OVF_vect )
  PORTB |= _BV(0);
  reti();
And how about nuvoton?
Help me please..
  • Most processors needs to use some magic keyword (the keyword name depends on compiler) like __irq, __interrupt or similar for interrupt handlers, to tell the compiler to add special entry/exit code to properly save/restore processor state.
    But ARM has added extra hardware intelligence in the Cortex chips to make interrupts look like normal function calls. So no special entry/exit code is needed for the interrupt handlers. That also means you can use 100% C code for a Cortex-M3 chip instead of having a need for a startup file written in assembler.
  • Normal Function, ie no magically entry/exit requirements to save context, or return-from-interrupt
    extern volatile uint32_t SystemTick;
      * @brief  This function handles SysTick Handler.
      * @param  None
      * @retval None
    #define TICK_RATE 1  // in milliseconds
    void SysTick_Handler(void)
      // Free running millisecond counter for timeouts
      SystemTick += TICK_RATE; // 1 ms tick count
